by Saba90 Investigator
Huawei P9 Update
Hi there,
Yesterday I recieved the notification for the system update I didnt have to update it but today I wanted to update the the notification has gone I went to the setting to check for updates manually but it says it is up to date but when I go on the info tab it is still 6.0!!
It is not letting me update 😞
Re: Huawei P9 Update
Try connecting to your PC and updating via Huawei PC software.
I tried doing that too via the HiSuite and it says exactly the same!!
Hi @Saba90
Welcome to the community and thanks for posting. 🙂
It may be worth backing up, then restoring the device to factory settings. This may force it onto the new software version:-
  1. From the home screen, swipe left.
  2. Tap Settings.
  3. Scroll to and tap Advanced settings.
  4. Scroll to and tap Backup & reset.
  5. Tap Factory data reset.
  6. Tap Reset phone.
  7. Tap Reset phone.
The device has been restored to factory settings.
Hi Chris,
I actually tried that too yesterday thinking it would work but nope still no luck at all.
It is really a strange thing to happen all of a sudden!!
Morning @Saba90
Thanks for trying this.
Give this a couple of days and see if the update appears again for you.
Let us know how you get on.
