by Kipperfillett Investigator
Huawei P9 Lite not loading or downloading photos on WhatsApp
I have a Huawei P9 Lite. Since using "Huawei Share" it will not load or download photos or video on WhatsApp. Before using "Huawei Share" it worked perfectly. I've uninstalled and re-installed WhatsApp, to no avail. What do I need to do? Any help very much appreciated!
Re: Huawei P9 Lite not loading or downloading photos on WhatsApp
You can try going into settings, then looking for applications manager and resetting all to defaults.
Not sure how Huawei Share interacts with WhatsApp but messages go over data with WhatsApp.
EE Employee
Hi @Kipperfillett
Please do let us know how you get on after following the advice from @Northerner.
Many thanks,
Lee
Hi Lee,
I have found a solution! I emailed WhatsApp and they repied suggesting I check my time settings, among other ones. I turned off "Dual Clock" and that fixed it. To gt there I did the following:
Settings
Avanced settings
Date & Time
Dual clocks - Turn this off.
Also ensure that "Automatice date & time - Use network-provided time. This was suggested by WhatsApp as if the phone time isn't the same as the WhatsApp servers a problem will occur.
Cheers :-))
Thanks Northerner,
I tried to do as suggested, but didn't manage to find a way of resetting to default. I'm sure that this is my lack of ability! I contacted WhasApp and did the following:
I emailed WhatsApp and they repied suggesting I check my time settings, among other ones. I turned off "Dual Clock" and that fixed it. To get there I did the following:
Settings
Avanced settings
Date & Time
Thanks again
Cheers :-))
Brilliant news @Kipperfillett
Thank you for sharing this in our community 🙂
Really pleased to hear that things are sorted out for you.
Cheers
Richard
