by James2272
Huawei P20 Pro rSAP
Does the Huawei P20 Pro support rSAP and of not, how do I let my car use my phone's data?
Re: Huawei P20 Pro rSAP
@James2272: Huawei P20 Pro - Full phone specifications
EE Employee
Hi @James2272 and welcome to the community.
Are you able to set your phone as a hotspot and connect the car via that way?
Many thanks,
Lee
by James2272
Hi Lee
I'll give that a go, would it be any less secure using my phone as a hotspot?
Cheers
Jon
Get Outlook for Android
EE Employee
Hi @James2272
As long as you have a strong password on the hotspot you will be fine.
I share my phone hotspot with my kids when they run out and I have had no issues,
Many thanks,
Lee
