Highlighted
by Skilled Contributor
Skilled Contributor
Huawei P20 Pro notification sounds
Hi
I have the new Huawei P20 Pro - great phone - I can't seem to be able to set different sounds for each notification such as email, texts or whatsapp.  Its confusing to have the same sound for all and I find I'm not responding to texts or Whatsapp as I think they are all email.  Does this functionality exist?
Highlighted
by Ace Contributor
Solution
Re: Huawei P20 Pro notification sounds
Hi @Vennwood. you should be able to change the whatsapp notification from the Whatsapp settings, notifications, notification tone.
For SMS I use ChompSMS which again allows you to change the default notification in the app, and not the usual Android Settings. Gmail also allows you to set a different notification from the app.
Give that a go and if you have any questions, come back here.
Cheers.
Highlighted
by Ace Contributor
Solution
Cheers.
Highlighted
Skilled Contributor
Hi chistery,
Thanks for that - I'll give it a try.
Highlighted
Hi @Vennwood
Hope you got this sorted 🙂
Come back to the community anytime.
