by DanniMac Investigator
Huawei P20 Pro - no voicemail notification
Hey,
Can anyone help? When people leave me voicemails i don't get a notification for them (or a text, or anything).
I've just logged in to find 4 messages, 2 of which were from 6 days ago that i didn't even know about.
Can anyone help?
Solution
Re: Huawei P20 Pro - no voicemail notification
It's VM OFF and VM ON that you needbto text to 150, just to be clear for anyone else having the same issue 🙂
9 REPLIES 9
EE Employee
Hi @DanniMac and welcome to the community.
This sounds very strange.
Can I get you to try the following:
  • Text VISUAL OFF to deactivate the service
Then try the following:
  • Text VM DIVERT ON to turn it on
Let me know if this helps with notifications 🙂
Many thanks,
Lee
Hi, thanks for your reply.
I've just done that so will try leaving mysef a voicemail from a landline.
I got a text message alert so that's great, thank you. I will keep an eye on this!
EE Employee
Brilliant @DanniMac 🙂
Keep us updated.
Cheers
Lee
Solution
by gslouzon
I am having the same issue - No voicemail notifications.  I have tried your suggestion, but am unable to text to 150.
Hi, are you trying to text VMOFF to 150? If so, are you getting an error message or reply at all?
by gslouzon
It says "Not Sent. Tap to try again."
Good Morning @gslouzon
If you are unable to successfully send this text I would recommend speaking with our technical team who can look at your account further.
Keep us updated on how you get on 🙂
Katie
