by Carlcso
Huawei P20 Pro Dual Sim
Do EE still only supply the single SIM Huawei P20 Pro or do they have the dual SIM now?
1 REPLY
by Ace Contributor
Re: Huawei P20 Pro Dual Sim
No UK network sells dual sim phones.
BrendonH (Android Expert) - Samsung Galaxy S8+ (Pie 9.0 Beta)
If I have helped you please click on the STAR/SOLUTION buttons below
