by mar_uk
Huawei MediaPad T3 8 Inch KOB-L09 Firmware
Can anyone from EE please  provide a link so I can download the EE custom firmware: KOB-L09C238B002 please? Huawei don't provide it as it is custom one.
Also, any advise how the dialler / phone call function can be enabled as EE have disabled it.
Many Thanks
MAR
6 REPLIES 6
Re: Huawei MediaPad T3 8 Inch KOB-L09 Firmware
Unless the firmware is available via OTA update, then there is no place it can be legitimately downloaded.
EE Employee
Hi @mar_uk and welcome to the community.
We are unable to provide firmware to download, you can pop into your local EE store and they have a machine that can back up the device and restores the correct firmware.
Let me know how you get on.
Many thanks,
Lee
by DomenicoV Investigator
At the shop will they also be able to enable the phone dialer. Really don't understand why EE wanted to do so. Even at Huawei they don't get it.
can you please make it available with the next FOTA? I believe lot of consumer will be happy with it.
Hi @DomenicoV
Thank you for your ideas and feedback.
Have a lovely weekend
Richard
by Steven_McG
New Member
I'm hoping someone can help me with this. My Mediapad has dialer disabled and I've been through Huawei and EE and no one is able to help me enable the dialer.
Any advice much appreciated.
I went through this already. As EE doesn't support conventional phone calls the dialer is disabled by default and there is no way to have it enabled.
Hopefully this helps
