by Skilled Contributor
Skilled Contributor
Huawei Mate 20 Pro widget resizing.
Hi.
I've had this phone for a couple of weeks and I must say it is fantastic..
But the last couple of days I have come across an issue when trying to resize any widgets on the home screen. Normally to resize you long press the item for a couple of seconds and when released you get blue 'handles' on each of the sides so you can click and drag to your desired size. Well a couple of days ago this started happening. (see pic)
You can see 2 handles, one on the left and one on the right and a blue oval in the middle of the google search thingy. As soon as you touch any of these the dots and oval disappear and it returns to it's former state. No way to resize.
I'm thinking I have touched something within the settings, but I can't find it.
Any help would be great!
Thank you.
[Image rejected due to it containing personal information]
Skilled Contributor
Solution
Re: Huawei Mate 20 Pro widget resizing.
So a bit of fidddling and find out it's because of the theme..
Crisis averted 🙂
Skilled Contributor
Solution
Crisis averted 🙂
Thanks for the update @Dragon_
Glad you got it sorted. Smiley Happy
