by LDSpence Contributor
Huawei Mate 20 Lite back-order
Any update on when the back order of the Huawei Mate 20 lite will be in?
Solution
Re: Huawei Mate 20 Lite back-order
Stock now in, phone being delivered today.
Hi @LDSpence.
Have you had an email with your order number?
Are you able to check the order tracker?
Jon
Hi @Jon_K
Yes I have.
The tracker says "awaiting confirmation"
It is a back-order and was advised it could take up to 7 days.
Was just wondering if there was an estimate on when the phones would be back in stock?
Thanks @LDSpence.
I'd advise keeping an eye on the tracker, it will update as soon as there is any change.
Jon
Solution
That's great @LDSpence!
Let us know when it arrives 🙂
Jon
