Highlighted
How to transfer data from s9 to a a3
How do I transfer data from my s9 to a a3 using smart switch
Highlighted
Re: How to transfer data from s9 to a a3
Hi @Tkwood70
Use the dongle which will be in the box and connect the cable, make sure smart switch is installed. - Then watch away.
I would however recommend any big files (photos,media) are moved onto your memory card to save time.
Thanks,
