by Gothorp23
How to switch on enhanced 4g lte on pixel xl
Hi peeps I have noticed that the 4g lte in settings is on but greyed out, is there a way to switch this on the Google pixel XL running android 7.1.1. cheers
Solution
Re: How to switch on enhanced 4g lte on pixel xl
Hi @Gothorp23,
Welcome to the EE Community.
Although it's greyed out, it's turned on by default.
You will only see the HD calling indicator when you are calling another HD calling compatible phone.
Is it greyed out in the on position.
See this thread here.
by Gothorp23
Hi thanks for that, but the 4g isn't working whilst u make a call as it doesn't come up HD calling like it does on the Samsung s7.
Solution
Hi @Gothorp23,
