by barry7
How to stop adverts which keep popping up and use my data allowance
by Ace Contributor
Re: How to stop adverts which keep popping up and use my data allowance
If you can use the app offline then turn mobile data and WiFi off when using it to stop ads. Otherwise unless they offer an ad free version there is nothing else you can do except stick to WiFi only when using it.
EE Employee
Hi and welcome to the community @barry7
You can turn data off to the individual app, which phone is it that you have?
Many thanks,
Lee
by barry7
Samsung galaxy S6
Sent from Yahoo Mail on Android
EE Employee
Hi @barry7
Please follow below path to set:
Apps > Settings > Data usage > Background data
1
You can then select which Apps can have access to data.
Many thanks,
Lee
