by Helenback68
How to put answer phone on
Turned answer phone off few months ago can't seem to get it back on
Solution
Re: How to put answer phone on
EE voicemail help pages are here.
by Profile closed
Not applicable
Hello @Helenback68 text the code VOICEMAIL DIVERT to 150 and wait for the response then call your voicemail service on 222 to listen to any welcome messages and restart your phone. 🙂
Solution
