by Allen1
How to permanently remove Samsung Galaxy phone screen padlock
Every time I receive a call on my Samsung galaxy J1 phone, a padock appears which locks any available on screen function. I have to tap it twice to make it disappear, but it does return again later, so I just have to keep doing it. Very annoying.
Solution
Re: How to permanently remove Samsung Galaxy phone screen padlock
Look under settings - display and increase the screen time out.
Or disable/change the screen lock under security.
Solution
by Allen1
Thanks Northerner(Maestro),
Will try it.
Cheers, Allen1
