by Mikeyh1
How to activate my cisco bt sgnal assistant
How do i activate my mobile booster for better signal cisco bt signal assistant
Solution
Re: How to activate my cisco bt sgnal assistant
Thanks @Mikeyh1
I've replied to your private message.
Chris 🙂
Hi @Mikeyh1
Are you trying to set this up on a BT line as this is EE. Maybe you need the BT community?
https://community.bt.com/
Thanks,
Hi @Mikeyh1
Welcome to the community.
Could you confirm if the signal box was sent out by EE or BT Mobile?
Thanks 🙂
by Mikeyh1
It was sent to me by ee
Solution
Thanks @Mikeyh1
Chris 🙂
