by Ann62 Contributor
How much data would I need on my fone to stream a 2.5hr film from Netflix please
How much data is needed to stream A 2.5hr film from Netflix. My ISP is down so I have no WiFi indoors do need to use my mobile for now, and I only have about 500MB left in my data plan
Solution
Re: How much data would I need on my fone to stream a 2.5hr film from Netflix pl
@Ann62   Have a look at THIS as it will depend on the definition of what your streaming.
Portsmouth
Solution
Thank you this made things a bit clearer for me.
Re: Portsmouth
It depends on what the movie quality as 4k will be massive. Either way 500mb probably isn't enough.
Re: Portsmouth
Hi @Ann62
Welcome to the community. 🙂
Streaming HD video generally uses approximately 4-6MB per minute.
So approximately 600-900MB for a 2.5hr HD movie.
If you're able to change the settings in Netflix to SD (Standard definition) it would approximately half the usage.
Find out more about how you're using your data on EE >
Hope this helps.
