by RajPatel
How do you connect to bt wifi
Solution
Re: How do you connect to bt wifi
You register & buy it @ BT WiFi .
If you're thinking you get it free with EE BB like you do with BT BB, well you don't.
by Brilliant Contributor
As far as I am aware you can't. EE and BT are run as different entities. You don't get BT wifi as part of your EE plan.
Solution
