by simon11
How do i get my number on pay as u go
How do I get the number up with pay as u go
by Ace Contributor
Solution
Re: How do i get my number on pay as u go
Hi
Just text NUMBER to 150.
Many Thanks
by Ace Contributor
HI, @simon11
Please can you explain more what you want to do with your pay as you go?
Many Thanks
by simon11
I need to get my number on pay as u go I don't know the number how do I get it
by Ace Contributor
Solution
Hi
Many Thanks
Hello there @simon11
Let us know if you need help with anything else 🙂
Thanks, Leanne.
