by Misshipley
How do i get a visual notification for voicemail on my Samsung galaxy 8
by Profile closed
Not applicable
Re: How do i get a visual notification for voicemail on my Samsung galaxy 8
Have you tried in Settings, Call, Voicemail Settings, Setup? Or in Settings, Call, Voicemail Settings, Notification Sound?
by Profile closed
Not applicable
Or maybe go Settings, Notifications, then turn on Notification LED. Also while there make sure that Do Not Disturb is turned off for Notifications and Sounds.
by Misshipley
Have tried all of those things thank you. No good I'm afraid
Get Outlook for Android
by Profile closed
Not applicable
Ok. Call your Voicemail and choose option 3 for Voicemail Settings and Features. You can turn on and off alerts from there too. Listen out for the options.
