Highlighted
New Member
How do i check on numbers called from contract
How do i check on tWhat numbers have been called from contract
Highlighted
Solution
Re: How do i check on numbers called from contract
@Margareta10  to look at past history of numbers you’ve called look on your device.  You can request itemised billing but this will only start once you’ve requested it and itemised billing is £2.55 per month.
Highlighted
Solution
