by Sueday68
How do I unlock my phone to any net work
How do I unlock my old phone to any network
Re: How do I unlock my phone to any net work
Hello there @Sueday68
If you follow the below links for information on unlocking any EE device depending on how this was purchased;
Just to let you know, if your iPhone was purchased directly from EE on or after 1 September 2015 will be unlocked automatically once the device reaches 18 months old.
This means you may not need to request your device to be unlocked if you purchased the Apple device on or after 1 September 2015.
You can now check the lock status of your EE device here or by texting UNLOCK to 150.
Let us know if you have any other questions 🙂
