by Pete55
How do I turn off my voicemail
Not sure how to turn off my voicemail I have suddenly started getting voicemails?
Solution
Re: How do I turn off my voicemail
Text VM OFF to 150.
Solution
Text VM OFF to 150.
Hi @Pete55
Thanks for coming here for help.
Has the advice from @XRaySpeX helped you turn your voicemail off?
Let us know how you get on.
by Pete55
Hi Leanne
Yes it is all sorted now, thank you to all that helped so quick a response.
Pete55
Excellent @Pete55
Glad you got the help you needed from the community 🙂
Thanks for helping @XRaySpeX!
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
