by Sarah_Warriner1 Contributor
How do I transfer apps to an SD card for Sony L3
I have just got a new sony xperia l3 and I am wanting to transfersome of my purchased apps onto the memory card however cannot find the option to do this, I did this on my old sony but it's not in the same place as before
I have tried the advice below on sony's website
To move apps to the memory card
  1. Make sure that you have an SD card inserted in your device.
  2. Find and tap Settings > Apps & notifications > App info.
  3. Tap an app that you want to move to the memory card. Note! Only some apps can be moved to a memory card.
  4. Tap Storage.
  5. If the app supports changing where it's stored, a CHANGE button appears. Tap CHANGE.
  6. Tap SD Card > MOVE.
However there is no app info option nor is there a storage option
Re: How do I transfer apps to an SD card for Sony L3
@Sarah_Warriner1   Try re-formatting the SD card in your device.
