by PhilippeT Investigator
How do I switch torch on EE Hawk on and off?
How do I switch torch on EE Hawk on and off?  it's not in the user manual
by Star Contributor
Star Contributor
Solution
Re: How do I switch torch on EE Hawk on and off?
Hi @PhilippeT, there's a torch button if you swipe down from the top.
On single swipe on mine, it's second from right.
On swiping down again and getting the full menu, there is a button called torch.
Thanks @Chris_B for tagging.
@PhilippeT  Maybe @Peter_C can help with this.    ( just found your YouTube channel Peter and you review of this device )
by Star Contributor
Star Contributor
Solution
Many thanks, got it
by Star Contributor
Star Contributor
Super! If you have any other questions, don’t hesitate popping back and asking us.
