by keith3 Contributor
How do I set phone to only send standard text messages not mms
How do I set phone to only send standard text as I don't want to be charged extra for mms texts.
Solution
Re: How do I set phone to only send standard text messages not mms
@keith3  Do not send pictures or emojis and do not send text messages to many people at the same time ( Group messages )   And some devices when sending a text that has more than 160  characters change that text message to a MMS so keep your text messages below 160 characters, blank spaces are counted as a character
6 REPLIES 6
Which phone? Which version of Android?
Hi @keith3
You cannot totally disable them. Unfortunately it's down to your own self control.
@Northerner: Can't we set Messenger Settings / Multimedia Msgs / Set Restrictions to Restricted or even Warn?
Solution
@XRaySpeX
Yes you can, but you can still send them even with those settings. The only way to avoid incurring the charges us to use self control and not send the messages.
Thanks.
@Northerner: Don't those settings at least prompt you if you really want to send when you can then back out? If not, what do they do?
