by nap999 Investigator
How do I set an engaged tone on S8
How can I set the engaged tone when I'm on another call, at the moment it just rings for the caller, they have no idea I'm on another call.
by Profile closed
Not applicable
Solution
Re: How do I set an engaged tone on S8
Hello @nap999 you can turn call waiting off by typing #43# in to your phones keypad then pressing call or tapping phone>settings>more settings>call waiting to stop other calls coming through when already on an active call. 🙂
by Profile closed
Not applicable
Solution
That's brilliant Tom222, thank you very much.
by Profile closed
Not applicable
You are welcome @nap999 come back to the community anytime if there is anything else you would like to know. 🙂
EE Employee
Glad you are now sorted @nap999
Many thanks,
Lee
