by Jayney1
How do I make my phone ring longer galaxy s8
 I have just got the s8 and the ring is really short. How do I make it ring for longer when someone contacts me?
Tia Jayne x
by Profile closed
Not applicable
Re: How do I make my phone ring longer galaxy s8
Hello @Jayney1 to change the length of time before a call is diverted to voicemail:
Dial **61*07953222222**entertime# then press call.
You can enter the time in multiples of 5 up to 30seconds 5/10/15/20/25/30.
For a 20second delay you would dial:
**61*07953222222**20#
To check the current time set:
Dial *#61# then press call.
by Jayney1
Hi Tom222 thanks for the reply. It is set at 20 it says. That isn't too bad. It's more of when my phone is ri going it don't ring long b4 it goes off but it is still ri going on my partners phone at his end b4 the voicemail kicks in. Can I change how long I can hear it ringing for?
Thanks Jayne
by Profile closed
Not applicable
Hello @Jayney1 just to confirm you mean the call is not being diverted to voicemail too quickly but your ringtone is not playing for long enough?
Have you tried setting any others to see if they play correctly? Is it that the ringtone is cutting out early or the one you have set is too short? 🙂
