by Alan54 Investigator
How do I get my data usage shortcut back on my mobile as I had to do a factory
 Hi how do I get my data usage shortcut back on my mobile as I had to do a factory reset now my shortcut has gone.idont want to keep in to keep signing in my ee account as it to ages to load up thanks
7 REPLIES 7
Re: How do I get my data usage shortcut back on my mobile as I had to do a facto
Which phone?
Can't you look under Settings / Connections /  Data Usage?
Or it the MyEE app you want? You can d/load that from the Play Store.
I have got the ee application but I will try what you think and thanks
By the I my mobile is a alba6 Android
Thanks! You're welcome :)! Glad I could be of assistance.
Hi @Alan54
Have you managed to find the information that you're looking for?
No I haven't not yet but thanks
What was the app that you were using before, @Alan54?
Do you know what it was called?
You should be able to see your remaining allowances through the My EE app.
