by LDS73
New Member
How do I fix the fingerprint ID on Huawei P20 pro
The fingerprint ID unlock has literally disappeared from my phone. Causing me major issues.
Anyone help?
Re: How do I fix the fingerprint ID on Huawei P20 pro
Hi @LDS73
Try factory resetting your device.
Hi @LDS73
I recommend following @Northerner's advice to backup and restore your phone. Please back up your phone and follow these instructions to restore it:
Step Action
1
Remove the Data Card, if applicable.
2
Scroll to and tap Settings
3 Tap System
4 Tap Reset
5 Tap Reset Factory Settings
6
Tap Reset Phone
(Erase system data and... message displayed).
7 Tap Reset Phone
8
The phone will reset data and reboot.
Let us know how you get on.
by Ace Contributor
@LDS73 What does it say in settings under Fingerprint ID? Have you tried to delete any there now, and re-enroll them?
