by Muscipula Investigator
How do I disable data allowance
I cannot disable the data tracker. With my video pass the phone adds the extra data on top of my usual cap.
There does not seem to be a way to remove daily warnings.
Andrue
6 REPLIES 6
Re: How do I disable data allowance
You can't! Your phone can't know which data usage is unmetered by EE.
Hi there @Muscipula
Thanks for coming here.
What device are you using?
Are you getting notifications on your device daily?
Leanne 🙂
I'm using a Huawei P20. The problem is I have signed up with the Video Pass deal.
I cannot disable the daily usage warning. When it occurs it cuts the feed which in turn stops Netflix for example.
Andrue
Hi @Muscipula
Thanks for coming back to me.
Do you have a data limit set up;
Go into Settings > Wireless and Networks > Mobile Data > Monthly and Daily Limits
Can you change these?
No I don't know how to change it so that there is no limit.
Andrue
Hi @Muscipula
Can you try going into your Huawei settings as below;
Do you have a limit showing?
