by Olliepops Investigator
How do I check EE network availability by postcode?
Service not available on my phone, no resolution after live chat with support who suggests I visit my nearest EE store! Since found out other users in my area are having the same problem today.
Solution
Re: How do I check EE network availability by postcode?
Hi @Olliepops
Under help at the top of this page there is EE network service checker.
Solution
Hi @Olliepops
by Profile closed
Not applicable
You can check your area for any possible faults by entering your postcode here.  You can also report a problem if EE have nothing showing.
Many thanks for your swift response 😀 I checked my postcode and there is indeed an issue.
@Northernerwrote:
Hi @Olliepops
Hi @Olliepops
Thanks for coming to community 🙂
I can see @Northerner and @Profile closed have helped you.
I hope whatever problem has been flagged, is easily sorted and you have full service again as soon as possible.
Thank you
Richard
