by Beau-20
New Member
How do I change my address without going into store
Can I change my billing address online or do I need to go into store or phone ?
by Brilliant Contributor
Solution
Re: How do I change my address without going into store
Hello @Beau-20 ,
Welcome to the community,
You should be able to change your address by logging into your account via the web, of course if this does not work, you can always ring customer service and they will do this for you.
Solution
Hello @Beau-20 ,
