by Gooner4876
How do I activate voicemail
Struggling to activate voicemail on my Samsung Galaxy 10, any ideas??
by Brilliant Contributor
Solution
Re: How do I activate voicemail
Hello @Gooner4876 ,
Welcome to the community,
Just text VM on to 150, otherwise if that does not work ring customer service and they should be able to activate it for you.
Solution
Hello @Gooner4876 ,
