by Roger22
How can I use my EE data to my laptop
Solution
Re: How can I use EE data to my laptop
@Roger22:
  1. Set up your mobile as a WiFi Hotspot (for tethering). It should tell you its network name & password.
  2. Connect your laptop to that WiFi Hotspot logging in to that network name & password.
Your laptop will then be sharing your mobile's data.
by Roger22
Solution
@Roger22:
Re: How can I use my EE data to my laptop
Good Morning @Roger22.
Welcome to the community.
This is brilliant advice from @XRaySpeX!
Please come back and let us know how you get on with these instructions 🙂
Jon
