Highlighted
by Contributor
How can I turn on wifi calling on an ee supplied Huawei p20 lite
How can I turn on wifi calling on an ee supplied Huawei p20 lite?
(ee's help page only lists older models)
Highlighted
by Contributor
Solution
Re: How can I turn on wifi calling on an ee supplied Huawei p20 lite
Acutally the way this was dealt with in earlier versions was under "Wireless & networks", where as now it appears (at least on some phones) under the settings menu for the phone app.
HOwever I did find something new today, which I hadn't noticed before, which was the search facility in the settings, and sure enough with the settings page open I typed in "wifi calling" and it lead me strait to the toggle for wifi callling.
So if anyone else is reading this thread in the future, I would say that is the way to go:
1) Open the settings on your phone
2) Search for "wifi calling"
3) That will take you to the "Wi-Fi Calling" section
11 REPLIES 11
Highlighted
by Brilliant Contributor
Look in the call settings
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
Also are you PAYG or pay monthly
Highlighted
by Contributor
Its monthly contract
Highlighted
by Contributor
I'm asking for someone else, so please can you describe how to get to the specific point as though I am a 5 year old.
Highlighted
Try following the instructions for the P10 etc in How do I use WiFi calling?
Highlighted
by Contributor
I think that is an earlier version of Android
Highlighted
by Contributor
Althought the intructions for the p9 look like they may work
So thanks for the pointer
Highlighted
Android hasn't changed that much.
It'll be in the same area.
Highlighted
Thanks! You're welcome :)! Glad I could be of assistance. You should be able to navigate to it as all Android settings are much the same path.
Highlighted
by Contributor
Solution
Highlighted
Hi @roga.
Thank you for sharing your findings with us in the community 🙂
Hopefully this will help other users moving forward.
Jon
