by Al100 Investigator
How can I connect my Hawk to my television?
Solution
Re: How can I connect my Hawk to my television?
If the TV has no mirroring function you can't do it.
9 REPLIES 9
@Al100  If the device is capable of this there are cables you can purchase,   I don’t know if you could use a google cast device.
Is it a Smart TV? It should have a Networking item on its menus for connecting it to a mobile hotspot on your phone.
EE Employee
Hi @Al100 and welcome to the community.
Have you tried connecting your device to your TV via USB cable?
I have a P10 and a Hitachi TV and this allows me to connect via this method.
Many thanks,
Lee
I tried an hdmi to USBC cable but that doesn't work. Any solutions?
What AV ports does the TV provide? Is it a Smart TV?
What exactly are you trying to achieve?
EE Employee
Hi @Al100
Have you tried using a standard USB cable with your device into the TV if your TV has a USB port.
Many thanks,
Lee
.my TV is a blaupunkt with HDMI ports. I want to mirror my phone on the screen. It is not a smart TV, but is fairly new.
Solution
by uvarvu Established Contributor
What about a Chromecast!?
