by Anniec87
New Member
How can I change my surname
Hi, I have phoned EE in the past to change my surname and it is still coming up as Dodd. I am now Cottrell and this is frustrating.
by Ace Contributor
Re: How can I change my surname
Hi @Anniec87  The easiest way is to go to an EE store with photo id and proof of the name change, E.g. marriage certificate.
