by JimWatts Investigator
Honor 7A
Do you know if the Honor 7A is compatable with WiFi Calling on EE?
Re: Honor 7A
@JimWatts   EE do not  guarantee it will work if you get the device from a third party seller.  Does that device even support WiFi calling ?
Re: Honor 7A
I'm not sure. Is there a list of handsets that support wi-fi calling?
Re: Honor 7A
@JimWatts   There is that’s HERE.
Its not a case of just EE supporting it it’s also a case of if the device has the feature built in to it
