by Topman2018
Hi my camera doesn't work on my Sony Xperia xz1 please can anyone help
Hi please help me with my Sony Xperia xz1 camera its not working
Re: Hi my camera doesn't work on my Sony Xperia xz1 please can anyone help
Can you try another camera app from the apps store to rule out hardware problems.
by Topman2018
Yes I've tried other camera apps and it says unable to connect to camera
Try factory resetting, if that doesn't work then you will need to take the phone into EE to send off for repair/quote.
Hi @Topman2018
Welcome to the community.
How did you get on with the factory reset?
