by Lizl Investigator
Hi, how do l control the sound notifications, constant beeping sending me mad
Hiya, please see top line thank you
Solution
Re: Hi, how do l control the sound notifications, constant beeping sending me ma
Hi @Lizl
That notification sound can be disabled in the email app, or via settings -, sounds notification sound (set to none)
7 REPLIES 7
Hi @Lizl
What device do you have?
What sounds are you wanting to disable?
On Android settings - sounds/vibration is the location for most sound settings
Cheers, have  a Huawei P30 lite....
Sent from my Huawei phone
Hi @Lizl
Have you checked under settings - sounds/more sound settings?
You haven't said what sound you want to disable.
Yep been through the settings options, put them at zero..... The only way l can describe is everytime l get an email from Google or Gmail or virgin l get a notification sound.
Thank you
Solution
Hi @Lizl
Hiya, thank you.... Seems to hv done the trick
Hi @Lizl
Thanks for coming back and letting us know 🙂
Have a great Monday 🙂
