by PaulFarley
Hi, how do I transfer data from a micro sd to my huawei p20 which has no slot?
Re: Hi, how do I transfer data from a micro sd to my huawei p20 which has no slo
Hi @PaulFarley
Are you sure that's the phone you own? I assume your phone is dual SIM?
You can normally connect Android phones to your PC and transfer data over, also you could backup online via Google Drive, Microsoft, Dropbox etc and then download to your phone.
Hi @PaulFarley
Welcome to the community. 🙂
I see @Northerner has offered a potential solution here.
Let us know how you get on.
by xiufu Contributor
If you just want to transfer data from a micro sd to your huawei p20, you need to use a sd card reading, connect it to computer. Then you can use coolmuster android assistant to help you import data on sd card to your huawei p20.
