by Shu
New Member
Hi I got a new phone it says not registered network. How do I fix this please?
Re: Hi I got a new phone it says not registered network. How do I fix this pleas
Hi @Shu
Welcome to the community. 🙂
Is the new phone a replacement or an upgrade? You should be able to put your old SIM card in, if you still have it.
Chris​​​​​​​
