by Anniebuckle Investigator
Hi, I changed my phone now my signal is terrible
Hi
I changed my phone on Sunday from iPhone to Samsung, now my signal is terrible, how can this be?
14 REPLIES 14
Re: Hi, I changed my phone now my signal is terrible
@Anniebuckle   different device manufacturer with a difference antenna in that device.
Hi @Anniebuckle
Welcome to the community. 🙂
Is it just the signal bars that are different? These can vary from manufacturer to manufacturer.
Are you having problems with your calls, texts or data?
Hi Chris
A bit of both, the bars don't seem to show any signal, my partner who also changed his phone is not receiving phone calls and works on call?
thanks annie
OK, thanks @Anniebuckle
Could you have a look to see if there are any network problems in your area? You can check on our network status checker.
Hi
The checker is saying I should receive a great signal inside and out, however my phone has the one tiny bar showing?
thanks
Annie
Hi @Anniebuckle
Thanks for coming back to us.
If you enter the postcode into our EE Network Status Checker here, does this show any problems in your area?
Speak soon 🙂
Hi Leanne
No, doesn't mention any problems
Annie
Hi @Anniebuckle
Thanks for coming back to me.
I have sent you a private message on here for some details.
Leanne 🙂
Hi Leanne
I cant see how to access the message?
sorry but need to leave home now but can check in later.
Annie
Hi @Anniebuckle
No problem, if you click on this link here to get to your private messages you will see my message to you.
Speak to you later 🙂
Hi I received information below, but I can't find wifi calling in my settings? Can you help,
Hi Ann, can you try this please.
1.Tap Phone.
2.Tap Options. (The 3 dots)
3.Tap Settings.
4.Tap scroll to WiFi Calling to enable disable.
Hi @Anniebuckle
Is your handset running on the latest software?
Did you purchase your Samsung direct with EE?
What model are you using?
Speak soon,
Katie 🙂
Hi
Yes, the Samsung phones we received are part of the package, from the EE shop .
I have a Samsung A40?
thanks
Annie
Thanks for confirming @Anniebuckle
I have sent you a private message, please take a look and get back to me.
Katie 🙂
