by Chelleby76 Investigator
Help terrible ghosting or screen burn
I've had my s7 edge for just over a year and the 'ghosting' or screen burn is terrible. Will it be under warranty still or how can i fix the problem? Any help would be appreciated
Re: Help terrible ghosting or screen burn
@Chelleby76. You’ll need to contact Samsung about this as they supply the warranty on this device as you get a 2 year warranty.
