by nadiasultana
Hawaii p20 Pro Home button not working
Hi
I have a Hawaii P20 Pro, it's only been a month, and the home button has all of a sudden stopped working?
Re: Hawaii p20 Pro Home button not working
@nadiasultana  Call customer services about this or contact Hawai about this as they will honour the warranty on the device.
Good Morning @nadiasultana
Welcome to the community.
I would recommend following the advice provided by @Chris_B and giving us a call, our technical care team will be happy to help further.
Thanks,
Katie 🙂
by Mpenny
New Member
Did you find a fix? My home button seems to have a similar issue
@Mpenny   If you are still within your warranty period just contact EE customer services or go to a store and it should get fixed.  If your out of warranty you’ll need to pay to get it fixed.
Hi there @Mpenny
@Chris_B is correct if you get in touch with us we will be able to help you get this sorted 🙂
Let us know how you get on.
