by Anders1975 Investigator
Have a Sony xperia xa was told battery life was 2days. I get 10hrs maximum.
I upgraded to a Sony xperia xa in February was told the battery life was up to 2days,if I don't use my phone I get a max of 10hrs is this a fault with my phone or just Sony xa in general! Only upgraded because of the expected long battery life. Thanks
EE Employee
Solution
Re: Have a Sony xperia xa was told battery life was 2days. I get 10hrs maximum.
It certainly doesn't sound right with so little usage @Anders1975
Definitely let us know!
Enjoy the rest of your evening.
Thanks - Karen. Smiley Happy
11 REPLIES 11
by Ace Contributor
Hello.
@Anders1975 Please have look here Sony Xperia XA - Battery - EE causes of discharge very fast.
Many Thanks
Hi thanks for your help, I shut down the apps after they are used so no back ground apps running, gps is off I also turn off the WiFi searching. So I'm abit puzzled thanks again
Sent from my Sony Xperia™ smartphone
by Ace Contributor
@Anders1975
If you are able to backup your data then factory reset your phone.
some time that can also help to improve your battery life.
as i always do with my xperia if i face any problem like this,
Many Thanks
OK will try that, thanks
Get Outlook for Android
EE Employee
Hi @Anders1975
You would find it hard to have any phone that had a battery life of 2 days - you would literally have to have nothing running on the phone.
I've had a look on GSM Arena and talk time says 10 hours.
I also found this post on the Sony forum.
Hope it helps!
Hi thanks for your response, the claim of 2days was from the ee spec's for the phone! I've done all the things on the link you sent have just had a system update from Sony earlier which Ive installed hop this might help! Thanks
EE Employee
Hi @Anders1975
The 2 days would of been in reference to standby mode.
It did mention on the forum that the update should help - so fingers crossed.
Pop back and let us know how it goes!
Yes I thought that, but as I use my phone to send 4/5 messages during the day I can't understand how it uses so much battery! Will message you back about the update! Thanks
EE Employee
Solution
Problem solved the update has worked battery is lasting over a day now! Thanks Andy
Great news @Anders1975
Thank you for coming back and letting us know 🙂
Have a lovely weekend.
