by trampus01 Contributor
Harrier Mini - How to transfer apps to micro sd card
My Harrier Mini is showing insufficient memory so I fitted a 32Gb micro sd card. I would like to move some apps to the card but 'MOVE TO SD CARD' is greyed out in App Info. The options that are not greyed out are:- FORCE STOP, UNINSTALL UPDATES, DISABLE, CLEAR DATA, CLEAR CACHE and CLEAR DEFAULTS. I have tried AppMgr III but it shows three apps can be moved but advises against doing so.
7 REPLIES 7
Re: Harrier Mini - How to transfer apps to micro sd card
@trampus01   Not all apps can be moved and it’s probably best just to move photos/music.
EE Employee
Hi @trampus01 and welcome to the community,
As @Chris_B has mentioned only some apps can be moved over to SD card.
Many thanks,
Lee
Hi Lee-H,
These are apps I have installed and are not apps that were pre-installed when I bought the phone. So if I delete them can I reinstall them to micro SD card?
Hi Chris_B,
Hi @trampus01
I would imagine you can, but I'm going to reach out to @Chris_B for some help with this one.
Or in the meantime if you would like to speak to our technical team they can support you.
Thank you
Richard
@trampus01  Even with apps your installing yourself not all of them can be moved to a SD card.
Thanks for helping @Chris_B
