by bry1uk
HTC M9, power button not working
Got a HTC M9, power button is not working, any other way of turning phone on?
Re: HTC M9, power button not working
You sure it's definitely broken?
You can try plugging it into a PC as that sometimes boots the phone. YouTube might be a good place to search for solutions.
by bry1uk
Yeah, its been playing up, and now doesnt work at all. Ive tried plugging into pc and that didnt work, tried all solutions found on google and you tube, and nothing as yet!
Good morning @bry1uk
Thanks for posting in community 🙂
You may need to perform a master reset on the device.
Is everything backed up first?
Here is the instructions from our HTC ONE M9 - PERFORM A MASTER RESET VIA HARDWARE help and support page.
Perform a Master Reset via Hardware
If you cannot turn the device on to access any settings, you can perform a factory reset by using the hardware buttons on the device.
  1. Ensure the device is turned off.
  2. Press and hold the VOLUME DOWN and the POWER button together.
  3. Wait for the HTC download mode screen to appear, and then release the POWER and VOLUME DOWN buttons.
  4. Press the VOLUME DOWN button to select factory reset.
  5. Press the POWER button.
The device will now reset.
Let me know if that fixes things?
Richard
@Richard_C
The OP power button is broken so the OP cannot do anything which will involve the power button (I would have suggested your post if it worked) Smiley Happy
@Northerner I got a head of myself, I didn't know if it would have worked even if it didn't power up.
Hands help up! 🙂 thanks for the heads up @Northerner
@bry1uk I'd speak to the technical team and they may be able to offer further assistance.
Cheers
Richard
