by margie07989 Contributor
HAWK mobile - camera shutter sound
I have just upgraded to the new EE HAWK mobile.  Am finding the camera shutter sound very loud.  Does anyone know how to shut ths off please
22 REPLIES 22
Re: HAWK mobile - camera shutter sound
@margie07989  If it’s possible it’ll be in the app settings or in system sounds.
by Skilled Contributor
Skilled Contributor
I dont think there is a way of turning off shutter sounds in european mobiles.  I believe it's to help with protecting people from unwanted images.  Perverts, up-skirt images etc...   Some other countries allow shutter sounds to be switched off but european models dont.  Some mobiles allow the sound to be changed but not turned off.
Thank you
I had already looked there but there is nothing
Thank you for your reply
I have previously found with all mobiles (including European) that I could silence the shutter simply by turning down the volume but this does not work with the HAWK
EE Employee
Hi and welcome to the community @margie07989
Let me look into this for you, in the meantime please do turn your camera on and select the in the camera menu.
It should be an option in there.
Many thanks,
Lee
Hi
Thankyou for getting back to me
I'm sorry but I do not quite understand your reply.  If you are telling me to go into all the camera settings I have already done this and there is no option for turning the sound sown or off
EE Employee
Hi @margie07989
Let me look into this further.
Many thanks,
Lee
ok - thank you
Hi
I have just received the following email from EE:-
"If someone's reply was so helpful that it solved your issue, tap the 'solution' button. This helps others with the same query find the correct answer.
And, it'll make the person who helped you feel appreciated!
If you didn't find the perfect answer, please post a comment to let us know. It's likely that other customers, such as our Community Stars, will help you out. If they can't help, a member of the EE Community Team will.
See you in the community.
Hi @margie07989,
That email is an automatically generated reminder. @Lee_H is looking for a solution for you and will get back to you as soon as possible.
Thank you James
Hi Lee
I am still waiting for a reply to offer me a solution for turning off the camera shutter sound.  Please can u advise me
Thank you
Hi James B
I have not yet had a rep;y from Lee to offer me a solution to turn off the camera shutter sound. Can you look into this for me please
Thank you
Hi @margie07989,
Sorry for the delay in getting back to you.
I've managed to get hold of a Hawk to test and it's not possible to turn off the shutter sound.
Thankyou James - do u think they might update their software to allow for this - I mention this because I was told in the EE Phone shop that this might be the case if enough people complain about it ?
EE Employee
Hi @margie07989
Unfortunately, that would be up to the software developers to make that decision.
Many thanks,
Lee
ok - thank you
margie
@margie07989  At present this is not possible on that device.
In fact I've just given you the solution with this answer.
A solution might not be what your want but it’s the answer to your question.
Skilled Contributor
I gave the correct answer and reason why on day 1 but hey what do I know 😄
