by eleiyas Established Contributor
Re: HAUWEI MATE P20 PRO - Dual Sim Question?
@James_B
I'm sorry, but multiple people are telling him it has a nano sim slot (physical) and e-sim capabilities, then you are telling him that's not true...
it's not about him finding the correct phone, it's about him getting the correct information.
everyone seems to be telling this person a completely different thing.
by Trevis58 Investigator
That’s another technical difference and yet another answer from EE.
by ifraser Investigator
Why not just swap for the Mate 20x I have the 5G version it has a dual SIM slot which is also a single sim+memory card
I asked if my phone was locked then happened to try a different networks sim in the second tray and it worked perfectly.  So solution found.
